Accessing Users
I would like to monitor for locked users in Autotask. What is the object name of the user in the API?
Hi @KeithTessler ,
Everyone who logs into your Autotask instance (whether that be an API user, an employee, or even a Dashboard User) are accessible using the Resource object in the Autotask API.
Thanks - I need to access the Locked field. But I do not see it. Do you know if we have access to it?
Deleted because I totally mis-interpreted your question :see_no_evil:
it doesn’t appear that Autotask exposes a field that describes whether a resource is locked.
You’d need to request Autotask add that field, unfortunately.
