Between strings when the content has ' in them
Hi, we are trying to extract some server names from an alert as below:
A replication job has failed to send data for ‘SERVER1’ to the Target Core SERVER2
I have configured the rule below:
{{between_strings email.body ‘for ‘’ ‘’ to’ flags=‘t’}}
However it renders the variable as ‘SERVER1’
How do we remove the ’ ?
Hi @dale
If the email contains this:
I would expect this to return SERVER1:
{{between_strings email.body "for ‘" "‘ to" flags="t"}}
You can use single-quotes or double-quotes to surround the strings. Since you need to include single-quotes inside the string, you’ll want to surround it with double-quotes (like I have here).
This may be helpful for you: https://docs.mspintegrations.com/text_replacement/text-helpers#denoting-strings-with-quote-marks
Another idea: since the only single-quotes are the two we care about, you could even do this (but I recommend using longer strings to qualify the text):
{{between_strings "'" "'" flags="t"}}
Ah ok. Didn’t know you could use " as well. Thanks that worked well.
