Creation of a project from a project template
I would like to build some projects from existing Autotask Project Templates - in the UI this is through
Create > Project from Template.
I have worked through standard project creation which is fine but can’t see a way in the reference guides to invoke the ‘from a template’ option.
Hi @alex
Thanks for posting!
Unfortunately, the ability to create projects from a template is only available in the Autotask user-interface, not the API.
To replicate this in the API, you would need to query the API for all tasks, phases, and notes, and then re-create those yourself. It is possible to do this in the API, but it is not simple, and I wouldn’t recommend trying it within MSPintegrations (it’s a bit too complex).
Thanks Travis, that sounds like an awful lot of work for a 5 click process which is fairly quick already!
Appreciate the response.
Alex
