Email Not Attaching to Ticket
Hi @travis
I am getting a problem attaching email to a ticket on an existing workflow.
The error message is
An exception was encountered: Autotask returned an unexpected response to command [query]: {“queryResult”:{“ReturnCode”:-1,“EntityResults”:{},“EntityResultType”:“attachment”,“Errors”:{“ATWSError”:[{“Message”:“Unable to cast object of type ‘autotask.web.services.API.Attachment’ to type ‘autotask.web.services.API.ExternalVbApiEntity’.”}]},“EntityReturnInfoResults”:{}}}
MSPintegrations
Could you assist me
Thank you
Hi Richard,
Thank you for the history log link.
That error came from Autotask’s API, and it looks like a bug on their side. Does this happen each time, or is it only happening sometimes?
Can you replay that same email message (click the triangle in the top-right) and let me know if it works the second time? I suspect that error was a transient error, and retrying it might make it succeed.
Thanks for your help!
HI Travis
Thank you, unfortunately I have already rerun the email and it still happening. It only happening on this workflow currently. It happen this morning on 4 alerts being generate. Will continue to monitor the a few days.
Thank you
Hi @Richard
Actually, this may be an issue on our end (either a bug in our software of a configuration issue in your rule).
Do you mind if I replay this message a few more times today?
Hi
You can rerun the message for further testing. If possible can you rerun the ticket during 09:00 to 17:30 UK time.
Couple of other message log with the same issue.
https://console.uk1.mspintegrations.com/#/email2at/advanced/history/173683563907371
https://console.uk1.mspintegrations.com/#/email2at/advanced/history/173683563907369
Thank you
