Extract First and Last name
I have an email that gives the first and last name like this:
I have been able to extract the first name with:
{{between_strings email.body “Name:” " " flags=“t”}}
But I can not get the last name. I have tried:
{{between_strings email.body {{custom.FirstName}} “;” flags=“t”}}
{{between_strings email.body “{{custom.FirstName}}” “;” flags=“t”}}
thanks
Try this:
{{between_strings email.body custom.FirstName “;” flags=“t”}}
Thanks for the after-hours response!
It returned: {{between_strings email.body custom.FirstName “;” flags=“t”}} as the contents of LastName. It did not process it. The email is [email protected] if you would like to take a look.
If you copy/pasted my example, it probably copied styled quotes instead of “real” quotation marks. Try typing my version instead of copy/paste.
That worked! - Thanks
Odd {{between_strings email.body “Name:” " " flags=“t”}} is now giving me an empty string. This was working.
Hey @KeithTessler
Can you share the URL to the error from your history so I can see it in context?
Travis,
There is no error.
The email is [email protected] ( MSPintegrations). Look at step 8.
Thanks,
Keith
