I want to change autotask integration credentials how do i do it?
Hi @ftsi
You can add as many credentials as you’d like, but the system limits you to connecting to one single Autotask instance. If you would like to connect a second Autotask instance, you can provision a separate MSPintegrations account (sign up again for another account) or we can add a second connection license to your existing account.
I will email you directly to discuss the details.
Travis
