Does anyone know how to indent items when adding checklist items to a ticket?
Are you able to indent them in the Autotask user-interface? Can you share a screenshot showing what you want to accomplish?
Thanks for the screenshot.
It doesn’t appear that Autotask supports indentation/nesting using the API. I would expect to see a property that relates the checklist item to another checklist item, but that property doesn’t exist.
The only way I can think of doing this is to create a Checklist Library in the Autotask UI with the nested checklist items present, and then add that Checklist Library to the ticket like this:
I can make that work, thanks!
