Is it possible to perform a spilt on custom variable. I have a custom variable called UserName which is a the first and last name of a user, and I need to perform a spilt to get the firstname and lastname into separate variables.
Hi @gdsTechJay
You can use a regular expression or text helpers to split a string. Regular expressions are more powerful, but also more complex, so I recommend a text helper in this case.
Assuming there is only 1 space in the name, you can use these:
{{before_string custom.username " " flags="t"}}
{{after_string custom.username " " flags="t"}}
Change custom.username to the variable containing the name. You can read more about before_string and after_string on the docs pages.
Could you show me an example using the user interface
