Is it possible to set an image size limit to prevent social media icons from incoming emails from being imported as an attachment. We have set the parser to prevent duplicate attachments but this does not prevent the creation of the attachments entirely.
Itās not currently possible to filter images by size.
Historically, we have been decidedly against this because it is a rudimentary way to filter images from a signature. We intended to release a much smarter method that tracks the number of times any particular image is received and suppresses that image once itās obvious that it is included in a signature.
That said, we have yet to release the tracking feature I described, so let me look and see what we can do to release the ability to filter by size.
Hi Travis, I have to add to this post, We love Email2AT, but this is the one thing that we would accept/beg for almost ANY feature, even a rudimentary one, even a way we could simply blacklist a word in attachment name, anything to clean out attachments even if we have to write it ourselves. This is more than a nuisance. Anything you can do is appreciated.
Over the past few releases, we have been gradually adding logic that will enable the platform to recognize when an image is included in many different emails. The idea is that, over time, MSPintegrations will be able to identify the same image across many emails and threads and start to suppress that image intelligently.
This approach replaces checking image dimensions, which we believe is less reliable. Instead, the system learns the patterns of repeated images and blocks those that are clearly part of signatures.
In my opinion, it would be better if the system filtered attachments intelligently rather than requiring users to blacklist attachments based on name, dimensions, or other specific criteria.
I would be curious to hear your opinion on this. Do you agree that it would be better for the system to automatically learn and filter repeated images, or would you prefer having fine-grain control that requires you to manually filter based on file name, image size, or other metadata?
Iād appreciate your feedback as we consider the options.
Ok, you askedā¦, and without bounds this is what Iād recommend, I used to be an amateur developer and Iāve stayed at a Holiday Inn at some pointā¦
Develop and expose the tools for fine grain control that also support generic operations on attachments.
Open those tools up to users for testing/use as soon as possible, let the early adopters test the tools that you are going to use under the hood when fully assembled to deliver your smarter system.
Those early adopters test, feedback on your architecture, and you can move onto the next pieces.
When done, you release the smart tool and everyone can test it while falling back on their custom solutions if it needs more work.
When fully realized, they turn off the old non-smart and use your new smart version.
If for some reason, the smart tool doesnāt work in one use case, users can write a tool of their own to address that case from the component tools.
The component tools/variables themselves have value that users will find other uses forā¦
This releases pressure on development, satisfies multiple needs, and I think is the best of both worlds.
I think the issue that needs addressing the most is the time that passes by while the perfect tool is being developed. Stated another way, I feel like if you exposed just a couple of variables, we could possibly write something immediately, itās so close! (a testament to the already existing architecture).
Iād like to bump this post and request this feature too. We have probably 20 notes of just a single image, itās almost to the point where Iām going to block image attachments (if possible)
Just did a ticket review with a customer. No less than six social media icons taking the entire page before we could see the conversation in the ticket.
I guess Iād add that Autotask has a size filter, which was used to easily over 90% effect to clean these up. That tool may be āsimpleā but it worked and we miss it, and I fear what customers think of their tickets. Even worse, Autotask doesnāt show them the graphic, so they have to download each one to inspect it. Ugh.
Automatic detection and filtering of signature images would be preferred.
But if we can have something in the meantime to prevent certain images being imported that would be great.
Some of our contacts have many images/banners in their signatures which clutter the ticket notes and time-entries.
I believe this because they have attached an animated png to their signature and the parsing doesnāt know how to handle it. I want to thank them for making their signature even more annoying. There are no other attachments or images in this original email, so thatās what leads me to believe thatās the problem.
Posting it here, because it does kind of relate to these email signature issues.
Thatās interesting. I see that you replayed the message after it was initially processed, and that the attachments both failed during the first run but succeeded during the second run.
The system no longer has the backend logs that would help me understand why the first execution failed, unfortunately, so Iām left guessing.
If you have any other examples (preferably more recent), Iāll take a look.
Also, to note: we have a newer release right on the cusp of going live, and this new release has a lot of rewritten sections in the low-level parts that might fix whatever caused this issue to begin with. Iād still like to review any other examples you have, but it may be a moot issue in a few days.
We love to see this feature too, because our ticket-timeline is filled with image crap. Iāve checked the API to clear the AT attachments based on size, but thatās not possible within the API. So it should be great to do that before importing, because afterward it isnāt possible.
This week I implemented a workflow in N8N using the Autotask module, that checks new tickets when they are created for attachments and deletes them based on pre-defined filters.
While this is working fine, the biggest take-away so far is that image size is not a reliable way of identifying signature images. In the below example, 001 and 002 were screenshots from the user to help describe their issue, all the rest are signature junk.
My fileSize filter is currently set at 10000, and increasing it enough to cover all signature items would have also deleted the useful content.
I also have file name matching for ālinkedinā, āyoutubeā, etc etc, but you can see in this case that would not help.
image007 is actually a Google icon, maybe a 100x larger than it needed to be for the size it was displayed in the signature.
Unfortunately, Autotask has no understanding of how large the images were shown on the email, but this info is in the html that Email2AT has.
Long story short, if this does get implemented in Email2AT, it would need to be able to filter by file type, name, size, and html display dimensions in order to be a full solution.
We have a feature in limited release currently that tracks the attachments coming through by email. Once the system sees the same attachment five times across your Autotask it will ignore that attachment in future emails. This means that common attachments in signatures will only be attached the first few times, and then will be completely ignored.
Would you like me to turn this on in your tenant? Your feedback would be invaluable.
With the new feature I enabled in your account, we compare hashes to your entire Autotask instance, not just on the particular ticket. Once a particular attachment has been attached 5 times in your Autotask or 100 times in all Autotasks that we interact with, the system will suppress attaching it.
Let me know how this works!
This does not depend on the attachment remaining in your Autotask. We keep a database of hashes to use to compare. (We donāt keep the attachments, just a unique hash for each attachment).
So far so good Travis.
I have not done an audit, but Tier 1 is reporting no obviously missing attachments, and a significant reduction in signature images.
When I am finding signature images attached there is no way for me to determine how often then have been seen previously, so Iām not able to determine if this working as intended.
