Scheduled Task - Create Recurring Ticket
Hi all!
I want to share my setup of recurring tickets.
First a very big “Thank You!” to @travis for helping me setting this up. :partying_face:
Background: Recurring ticket template function exists in Autotask but is a bit hard to work with.
Purpose: Create recurring monthly tickets on block contracts that have UDF: “Monthly Controls=Yes” enabled. Second is to attach a check list to every ticket and assign the ticket to the primary resource stated in the “UDF: Primary Resource” on the contract with “UDF: Monthly Controls=Yes” enabled.
Pre-requisites: Two UDF’s on Contracts in Autotask: One UDF stating if the contract is to be used as a monthly recurring ticket and one UDF containing consultant names and ID’s.
Step 1: Query for all contracts with UDF “Monthly Controls” eq Yes (Autotask Direct API Calls/API: Query for one object)
Step 2: Iterate over contracts to create tickets (Control Structures/Iterate through multiple items in an array)
Observe iterate to custom.contract
Step2: Step 1: Create Ticket (Autotask Direct API Calls/API: Create an object)
Observe {custom.contract} and store result in custom.ticket
Step2: Step 2: Add Checklist (Autotask Direct API Calls/API: Create an object)
Awesome! Thanks for sharing, @Cynaps_Fredrik !!
