dale
October 25, 2023, 1:06pm
1
Hi all, sorry for my posts. I am trying to work out the best action to use to update an existing Monitoring alert ticket. There are lots of actions for updating, We essentially want to:
Put body from email into new note
Attach original email to the ticket
Stop posting duplicate attachments as well
Set Queue
Set Status of the ticket
travis
October 25, 2023, 4:56pm
2
Hi Dale,
This workflow will likely consist of the following steps:
1. Query Autotask for the existing ticket
Action: API: Query for one object
Entity: Ticket
Store results in Variable: custom.ticket
2. Create a note on the ticket
Action: API: Create an object
Entity: Ticket Note
The TicketID property should be set to {{custom.ticket.id}}. All of the other properties can come from the email.
3. Create attachments
Action: API: Create Autotask Attachments
Parent Type: Task or Ticket
Parent ID: {{custom.ticket.id}}
Publish: Your choice
4. Update the ticket (set QueueID and Status)
Action: API: Update an object`
Entity: Ticket
The ID of the resource to update: {{custom.ticket.id}}
Add the QueueID and Status fields and set them to correct new value.
I will add a feature request to add the ability to prevent duplicate attachments when using the API: Create Autotask Attachments action.
