When I go to uses the variable ItemList, it is missing from the list of variables and when running the workflow I don’t have any information in the variable.
We identified an issue with the auto-complete within the “Iterate” action step and pushed a hotfix to the beta console. I think this issue is what you are experiencing - would you mind checking the behavior in the beta console to see it’s resolved?
The beta console configures your live mailboxes, and you are welcome to make your change and build your rule the beta site (assuming this fixed your issue).
In any case, the beta console version will be deployed to the live site by the end of this week.
Hi Travis.
The specific issue I was having was resolved in our previous thread, and I was confirmed able to work with iteration on the June 3rd. No issues since thank you.
